Hi
Have been checking the house wiring on my old wylex consumer board. With the board disconnected and the downstairs power Ring Main disconnected there is continuity between the live and neutral legs. On investigation I found that by disconnecting the Fridge and Freezer from their sockets the problem disappears. I plugged them into the Upstairs Ring Main and the problem moved to the upstairs and disappeared from downstairs. Either of them plugged in and the problem arises again.The other appliances do not throw up this fault. The electrics are working OK and have never had any major problems over the years.
I would be grateful if anyone has any ideas why the fridge/freezer affects the circuit in this way and is it normal.
