Hello,
I'm having some issues with my Bosch live wire detector as per the link at the bottom of the post.
It's a long story....
I'd like to drill some holes in a wall to mount a cupboard, the wall shouldn't have any live wires in it, however the previous owners had a habit of doing things to the house that they shouldn't so I tested for live wires.
Initially I swept the wall and it found nothing. After I'd marked where I was going to draw the holes I put the detector on them and it showed the lighting symbol for electricity but was the indicator was still green and wasn't beeping, I understand this to mean it's in the rough vicinity of a live wire but it's not a problem. Perplexed I checked again and this time the indicator went red and it started bleeping as if if was right on top of a live cable. I had someone else check and it went back to being green but showing the lightning symbol.
I then checked another wall where I know there is the cable for the light switch and it showed the symbol, went red and started beeping. I then tried it on another wall where I was sure there wasn't a cable and it showed the lightning symbol but stayed green and didn't alarm. I changed the battery and then tried again.
I went back to the original spot where I want to drill and now the lightning symbol may or may not appear, it stays green and it isn't alarming.
Any ideas what's going on? Or how I can check for certain that there are no live cables in the wall? I finished painting the wall yesterday so maybe the paint hasn't fully dried and is causing the problem?
The previous owners had a cupboard mounted on that wall and it was really high up, almost unuseably high which when the detector started going off made me suspect that they had to put it so high to avoid a live wire.
Any help would be greatly appreciated.
Cheers
George
http://www.homebase.co.uk/webapp/wc...ay?langId=110&storeId=10151&partNumber=277498
Cheers
George
