Evening all,
Looking for any advice would be great.
I live in a 1960's mid terraced house and plan a little DIY to the kitchen. I have removed most f the plasterboard and had a good look. There is 1 wall causing me a headache. I will try to explain.
House from wall to wall is 18ft. Beams are 8x2 spaced 18" apart. Beams that I see are all one piece spanning the full distance.
The wall in question comes into the kitchen from the backdoor about 4 ft then stops, it does not continue on anywhere and connect. There seems to be three ceiling joists sitting on it but the rest if the joists in the kitchen have no support the full 18ft. Can this be load bearing? There is no wall directly above and in the loft the ceiling has the joists running the whole span into brick. Phew all done.
Any advice welcome and if any more info required I will do my best to give it to you, I am good with cars not building so if I can help there please ask!
