local paint repair
5 Mar 2008
Essex
Some mindless moron has kicked a dent in the door of my Mondeo, and to save money I was looking to do a local repair. I have resprayed classic cars and bikes using cellulose, but have never tried doing a local repair using clear over base. My question therefore is can you blow in a small area as with cellulose, or will I have to do a full panel repair?
Have a look for a mobile dent repairer in your area. May be able to pop it back out without needing to respray
How bad is the dent?
I've seen a very good trick where a guy uses a hair dryer to heat a panel up, gets it good and warm, and then suddently sprays freezer spray on the panel, and the rapid temperature change causes the dent to pop out.
Might be worth a try?
I think you can find the vid on youtube.
Ilike the sound at this, and will certainly give it a try
