Hi all,
Looking for some placement advice for a MagnaClean Pro 2, that I am planning to fit on my inherited system
The system was power flushed at some stage and my aim with the MagnaClean is to prolong the life of the system, as we have had the pump replaced twice before - each time with metal shale found on the pump impeller...
(p.s. this is normally covered by a cupboard, which has been temporarily removed for access)
View media item 58263 - View media item 58267
As it stands, the pipe work is a bit of a mess - nothing is straight and only some pipes are clipped - I was tempted to drain down completely, cut out the crap and re-do some of the runs, clipped and with enough space to use insulation foam on the pipes too (to reduce heat loss and noise)...
View media item 58265
Would this be a sensible thing to do? Should I be concerned about the current state of the runs (i.e. they are introducing air pockets) and the fact that I would only be able to replace with solder ring bends or compression fittings (as I do not have a 22mm pipe bender)?
I have noticed, at the top of the boiler, the fitter has handily marked the Flow and Return in pencil on the wall. I understand, I should fit the MagnaClean on the Return, as close to the boiler as possible?
View media item 58266
I propose the following location - circled in red, to make maintenance easier (not so high) and be close to the boiler on the Return - any issues in doing this?
View media item 58264
Please do let me know if you need any more details - thanks in advance!
Boiler - Vaillant ecoTEC Plus 428
Rads - 7 rads only, 5 upstairs, 2 downstairs - no doubles.
Pump - Grundfos UPS 15-60 / 130 (recently replaced by AA insurance with the latest revision / model)
