Location of bathroom extractor outlet
14 Aug 2007
Berkshire
Hi
I'm installing a bathroom but it won't have a window. I know for building regs it needs an extraction fan to an outside wall. But could I duct this to an existing but unused chimney?
Andy
not a good idea .as the damp air wouldn`t do any good at all :mad: chimneys are for hot air :idea: like the plumbing forum :rolleyes:
it can be done, but you may get excessive condensation forming within the flue. maybe if the fan was allowed to run on, after the condensation has died down, this will help to keep it dry.
i know two people who have had it done with no side effects. both houses are pre' 1920's and would have originally burnt solid fuel.
what is above the bathroom?
does it have an outside wall?
what rooms are around the bathroom?
There's no outside wall, I'm putting this in the middle room and creating a corridor to the back room, squeezing an upstairs bathroom in a 2 up 2 down terrace is quite a challenge...!! There's a loft room above the bathroom, but immediately above where I want to put the extractor is an eves space, I guess I could duct it through there and out under the soffit.
I'll take that 'yip' as an affirmative, still seems a shame not use the chimney, poor thing probably hasn't been used in years...
