Since - like many - our summer holidays were all cancelled this year, I had a moment of madness after chatting with a mate and ordered a hot-tub. Was amazed to find a number of retailers out of stock, they are apparently having the best year ever as I'm not the only one with this idea. So much for being an individual...
Anyway, having duly cleared the space in the corner of the lawn of weeds and shrubs, I am setting about building a 5m x 5m deck to accommodate said tub and an adjacent gazebo.
I'm using treated C24 timbers 47 x 150mm for the entire frame, using BCP steel joist hangers, and will space the joists 400mm apart. I'm going to then floor the deck in 18mm construction OSB as it will then be covered with some very nice fake grass. Probably over-engineered, but the tub with 5 people in it could weight 2 tonnes.
I want the deck to float just above the grass. The surface is pretty firm as our substrate is almost all chalk, which you hit with the spade only a few inches down.
Since the deck is low, ideally just almost sitting on the grass, I was thinking about using the following product for levelling the frame directly onto the surface:
https://www.stratarise.co.uk/index.php/products/3560ml-df-pedestals-for-decking-flooring
The spec says they are point load tested to 800kg per unit. If I space then under the tub at 500mm intervals on every joist under the tub, then that will be 30 supports and a (theoretical) combined load capacity of 24,000kg or 24 tonnes!
Has anyone used these units before and have any experience with them? They seem to get only 5* reviews on amazon, but would be good to hear if anyone on here has used them.
Jock
Jock
