Hi. I have a leak coming through the pin of a lockshield valve. When the valve is shut all is fine, although of course there is no heat to the radiator! When I open the valve I get a leak through the pin. I am assuming the pin is loose or damaged which is causing the problem? To fix this I am assuming that I will need to fix a whole new locksheila valve? Or is there a way of replacing the pin? Any advice appreciated.
Steve
Steve
