I have a loft ariel and the easiest method to get the cable down stairs is thru the ceiling down the wall and then into a connect box next to the double socket for neatness, I then need to chase a line down the wall and plaster over, is this ok or is there a better way, If I go outside from the loft first it will look a mess still going down the outside wall and then I'd need to drill thru outside - in.
Any advise appreciated as always
S
S
