Hoping for some guidance here please.
I've just fitted a 2 section timber loft ladde. It's almost perfect. The highlighted plank is connected using 2 nails to each vertical beam and it obstructing the ladder from sitting in it's true safety position by about 3 inches.
Would I be able to cut the add 2 replacement timbers, one above and one below where the ladder will sit, at the same angle and cut the 'offending' section out?
Thanks in advance
Thanks in advance
