I intend to board a small area of my loft to provide additional storage space at home. As there is already around 30cm of insulation up there, I will need to build some sort of suspended floor frame on which to fix loft boards.
What size and grade timber is required for such an application - ie to construct the frame? The frame will be hung each side from the main structural beams in the roof space - will this be OK?
For info the house is a 1930s semi and hence I will not need to remove anything from the loft structure to create extra space! I just need to know that effectively hanging new joists from the 2 main beams will be OK.
