Hi guys,
I know this topic is probably done to death but having looked around this morning and watched a few youtube videos I am still a little unsure of whether what I would like to do is ok as explained below.
Due to the location of the truss members, my intention would be to insulate and board the centre area of my loft space for storage (using Kingpan/Celotex thermo board insulation between joists and chipboard direct to joists) and insulate the outer area with the existing mineral wool to 270mm.
My plan for the centre area would be as follows:
The bit I am confused about is whether this would be fine as there is plenty of mention of mineral wool between the joists followed by thermo board on joists then chipboard on top etc but I couldnt see whether simply having thermo board alone is ok? Then there was mention of cold bridging and I was unsure whether this would be an issue with my plan. The area below the thermoboard would not be a bathroom as this would be under the existing mineral wool insulation and appears fine.
I intended to leave 30mm gap for ventilation, should this be above or below the thermo board of split both above and below or can I get away with 120mm thermo board to increase the insulation?
I did look at extending height of joists to take 270 mineral wool but price worked out similar once I had bought the timber.
I appreciate your input.
Thank you
Thank you
