Hijacking the post. No Apology.
mreco, thanks for the tip on not buying the 1220 B&Q boards. I was just about to, for my 600mm centre joists. I was assuming that the extra 20mm was for the TnG to overlap over the joist at the joint of the boards. Are you sure it isn't?
My joists are 35mm wide and 100mm deep spaced 600mm apart. Are they strong enough and are there enough of them for boards?
Also, masona, you say "Are they gang nailed trusses, if so, you have to board it a difference way". My trusses are gang nailed (a new term to me!), in what way should I board it a "different" way, and why?
You have me hesitant to start now!
Cheers.
Cheers.
