Loft Boarding issue
14 Mar 2005
Part of my loft is boarded over insulation.
I've installed some spotlights into the ceiling but not wired them up yet but the connections are raised above the level of the boarding by an inch or so.
I suppose I can either: raise the level of the boarded area with approx 2"x 2" timber (probably about 20 sq m). This is a shame as it only affects 2 spotlights, or, (probably the lazy and unsafe way) drill a large hole so that the conncections are exposed then try and locate a form of cover to protect them. The wiring will be fixed under the boarding.
Am I right in assuming that the first option is the only way to go.
Many thanks
Unless the spots are sealed fire rated spots they will need to dissipate heat. As a result you will need to make sure the insulation is cleared away and that they are not covered over by your boards. You can get fire hoods screwfix 70589.
