Just wondering if anyone could help me with something thats been rattling my brain for a few days? There's a few issues so i apologize for the novel im about to write!
In the summer i am going to empty all the junk from my loft so that i can completely board the whole thing. Joists, eaves and gable wall ect. I am also having a combi boiler fitted and the water tank in the loft removed. This means that the airing cupboard will be used as access to the loft via ladder up through where the tank used to be.
Heres my plan so if there is anything im doing wrong please put me right before i wreck my house.
Im going to tongue and groove board the floor first with all the extra insulation and cross battens ect. I was wondering tho if i could completely enclose the whole loft with foil insulation beforehand leaving an air gap all the way round the outside for airflow?. So if you imaging a sort of suspended room within the loft with 270mm of wool then a layer of foil under the floor. The only air entering the inside of the room will be thru the hatch.
would condensation form in the floor if i put foil under it ontop of the wool? Bare in mind there will be a 50mm gap round the perimiter of the floor.
I plan on stapling the foil to the eaves then putting batten over it to fix the plaster boards to.
Im only going to use the loft for storage but wanted to mate a feature of it at the same time. Thanks
