I recently had my old open vented kitchen boiler replaced with a loft system boiler. All works fine apart from one issue:
If the 3 port valve is at rest with CH and HW off, ie in the hot water position, the hot water in the indirect cylinder upstairs heats the water in the coil which then gravity feeds backwards up the flow pipe to the boiler and back round. The result is loss of much of my hot water during the course of the time the system is off.
I could cure it by replacing the 3 port valve with 2 x 2 port valves, but that would be fair bit of work and cost. The other idea I thought of was a single check valve between the 3 port valve and the cylinder. Would that work okay, or cause any problems ?
