i noticed just before xmas there was condensation in my loft.
it seems to be mainly above the bathroom. the house was built in 73 i think, and has approx 8 inches of loft insulation.
the condensation is on the felt under the tiles, and on the wooden beams.
ive put batten peices in between the felting above the bathroom to space it out, which seems to have helped with the airflow.
i purchased some 70mm vents and a hole cutter, and today put a vent in the soffit. i was going to install a load more, but i dont think this will have any effect, as due to the angle of the roof you cant get right over to the edge, but what i thought was the inside of the fasciaboard seems to be brick/concrete that supports the beams?? i got my girlfriend to shine a torch into the hole, and i cant see the light from in the loft?
is it worth me installing more vents, or is there any other simple way of venting it up there??
would it help if i use an acrylic paint on the bathroom ceiling?
