A couple of years ago I had my roof replaced on my 1930s detached house. Grey Marley tiles were used with a breathable membrane. I suspect 2 types were used. 2 elevations have a membrane I can't name but it is grey on the upperside with occasional red dashes on the underside which is white.The other 2 elevations have membrane made by Klober. It has the makers name on the upperside. This side became quite wet with condensation during the winter. The eaves were enclosed and so I had soffitt vents fitted between each rafter and then had the pleasant task of pulling back insulation which was well and truly packed into the eaves and multiple old birds nests. Gradually the condensation has improved 95%. I have some queries which I would appreciate any guidance on:
1. Today, a cold day, I have no condensation. But yesterday there was some very very slight wetting of the membrane well down in the eave . Is this important?
2. At some point chimney stacks have been dropped and an extra joist has been fitted deep in the eave. Obviously this limits air flow in these particular areas. At the moment they are dry but is this a cause for concern?
3. The insualtion is very old and very thin. the entrance hatch is not insulated at all. I intend to re insulate in 4 or 6 inch insulation and board the loft including the hatrch. Will this reduce any chance of future condensation?
Thanks in advance for any advice.
