Been thinking about a loft conversion on our semi built in 1929, so got a couple of quotes from local specialists. They both want more than £40k for the job, which was a shock, my research on the net had led me to expect something nearer 20k. Have prices gone up so much?
The house is 6m x 7.6m (internally to outer walls), none of the internal walls are load bearing so steels needed, the rafters are 95x50 with purlin and ridge is 2.9m above joints. The chimney stacks on the party wall are 5m apart at joist level and both in use. The obvious structural design is to fix steels either side of the stacks across to the opposite wall and run queen posts up from them to the rafters (need doubling up?) forming the short walls. Access to be via a double winder staircase up into a side dormer, which we would like to be room width (that is dormer walls also supported on the steels). We just want a single room conversion (no ensuite etc.), but maybe a rear dormer too. The resulting room floor area is approx 5m x 4m, but the side walls are very low so the usable room quite a bit smaller. Really a very average kind of conversion for a semi.
Can anyone advise me what something like that should cost, either what you have paid recently or what you would charge?
Could I save money by managing the project myself, or am I more likely to pay more as an individual for the services (architect, SE, scaffolding, skip, plasterer etc.) and materials than the loft specialist takes in profit? I am competent at DIY, done brick work, rewired the house (pre part P), plumbed in the bathroom etc., so beginning to wonder if I could do it myself or at least be the grunt labour. Any money saving suggestions?
I just can't see how parts and labour for a single room conversion (admittedly to BR standard and plaster finish level) add up to £40k. Is this a fair price?
