I am about to start a loft conversion in my 1950's semi and have a question about the new floor joists i will be putting in.
Currently there are 100mm ceiling joists and i will be running 200mm floor joists alongside. The property has brick built cavity walls. Presently the ceiling joists run over the internal leaf through to a wall plate on the external wall. I would like to sit my new joists on the wall plate also, but due to the increase in height, being 200mm instead of 100mm, these would need to be chamfered to fit under the pitch of the roof. I can ask my SE to check if ok but seeing as there is also an internal leaf to the cavity wall can i run the joist from the external wall plate and pack the internal wall up, say with mortar maybe?, to ensure the joist sits on both the wall plate on the external wall and also sits on the internal wall? This waould ensure the intergity of the joist is not too weakened by the chamfer.
thanks
thanks
