Hi - I am going to replace the plasterboard in the bathroom in the loft.
What type of insulation should I use, there is a gap of about 500mm from the party wall (in roof) to where the stud wall is.
There is nowhere to secure the new blanket of insulation unless I put some sort of plywood on the outside of the stud wall so that it can hold the insulation inwards. (hope am making sense here)
Is there any other easier method to do this as getting plywood thro the studs would be a problem.
Would space blanket be OK? I have purchased some 150mm space blankets and hoping this can be used in the walls?
Any advice appreciated.
