Hi Guys,
Sorry if this might have been covered before, I’ve had a look to see but couldn’t find the help I needed. I’m new to the forum and have been doing fine with my DIY until it came to the wiring….
My Gran used to live in a loft conversion on the 2nd floor, she had a fully contained kitchen, middle landing light and 2 lights, one in each room. Imagine it split into 3 room in a row. Kitchen Light, landing light and bedroom light.
She moved into a fully managed care home and so I decided to gut the loft and redecorate with a new on-suite, bedroom and separate study. All the building work was completed and the existing wiring was left in place, only replacing the light switches and power socket casings to modernise it.
Only one problem remains from the work…No lights! Reason being is the 5amp fuse wire keeps blowing every time I switch on the middle landing light above the stairs leading down to the first floor of the house.
The ground floor of the house has a double 2 way light switch. One switch controls the hall way light, the second controls the 1st floor landing light. On the 1st floor landing is another double 2 way switch, the left one works in conjunction with the Hall way switch to turn on and off the Landing light, the second switch operates the same scenario with the 2nd floor landing light. Does that make sense?
The 2nd floor light switch is a triple 2 way switch. The middle switch is for the landing light above the stairs, the left and right ones “should” turn on / off the Study lights and the bedroom lights respectively.
Now the confusing part.
Cables….I have a single white shielded cable leaving the 1st floor switch upto the loft:
Yellow in common
Blue in L1
Red in L2
Earth
This goes up to the Second floor where is enters the triple 2 Way switch from the bottom of the box.
Into the top of the light switch box are 2 more cable bundles. A Grey shielded cable containing an Earth, a Red and a Black (I assume this is for the lights on the left and right?)
There is also another white shielded bundle containing the 4 cables Yellow, Red, Black and Earth.
My Question is how to check if the Switch is correctly wired to allow the following.
Left switch turns on / off study light
Center switch turns on / off 2nd floor landing light (In conjunction with 1st Floor switch)
Right switch turns on / off bedroom light
There is a common, L1 and L2 on the back of each of the 3 switches for wires…there was a cable bridge across 2 connectors but I cant remember which ones. 2 of the Red cables (1 from the feed going upto the 2nd floor and and 1 from the Grey shielded bundle coming into the top of the switch) are wound together. Also the Black (from the Grey cable) and the Blue (from the top feed) are also wound together.
Any help on this would be much appreciated as I’m sure someone out there will know what I’m talking about.! I Hope!!!!
Yellow in common
Blue in L1
Red in L2
Earth
