I have a 1930's 3 bed semi with a hipped roof, and had some plans drawn up 2years ago for a basic loft conversion consisting of a single bedroom, the stairs were open from the 1st floor into the loft and a partition & fire door at the top. I have since decided to amend these plans to put the fire door at the bottom and the loft can then be open plan (making the loft visually larger). The loft floor joists sit on the wall plate at one end, a bearer bolted to the party wall at the other, then on a structural wall in the middle overlapping the joists and bolting them together. This wall is constructed of brick but is offset from the wall below it(ground floor) and is built on a rsj spanning 3/4 of the length of the house front to back as originally built. Do you think this may be a problem and was possibly an oversight of the architects? The original plans did pass building regs but they don’t show the position of the ground floor walls, just the 1st floor. I am renovating the property and currently the 1st floor ceilings are down and think this would be the best time to fit the loft floor, I was considering lowering the new loft joists by a brick height so that the loft space height slightly greater than it would be without. On the party wall I was going to bolt a timber bearer with joist hangers to support the floor joists, but at the other end the bottom of the floor joist would be level with the bottom of the wall plate, I’m not sure if fixing a joist hanger onto the 4" wall plate would be sufficient for a 75mm width joist, any advice?
