I've got a large loft space (approx 50m2) and I'm looking to put down loft boards to use as storage space. I am probably going to get the 3 pack tongue and groove chipboards from Wickes.
It sounded like an easy job until I noticed that my electrician has put the wiring for all the (downstairs) lights OVER the joists rather than through them. All the lights are LED so theres lots of lights which means lots of wires overlapping everywhere.
Should my electrician have drilled through the joists to begin with? (It seems reasonable to expect that anyone with a large loft would at some point want to conver it.)
I've pondered a few solutions but not sure what to do:
1. Get the sparky to rewire, drilling through the joists (for which I gather he needs to put down protective plates),
2. Use 'loft legs'. These are used to prevent insulation compression but could also divert the wiring problem. It will add £50 or so to the job and make it a lot more effort having to fix all the legs to the board and then scren all the loftboards to the legs.
3. Use pre-insulated loft boards? - these are twice the price of normal loft boards - I was thinking the cushion would resolve any imbalance caused by fitting over the wires.
Any other ideas or advice on the above would be appreciated.
I also notice the sparky has pulled up all the rockwool insulation. He tells me it's safe to put back over the LED lights so hopefully that's true.
thanks
Nick
thanks
Nick
