Loft Header tank
Status
Not open for further replies.
14 Jul 2005
Yorkshire
Does it matter what size your header tank is in the loft ?
I'm trying to improve the hot water pressure and volume that's all for a new mixer shower that's just been installed. It's only a small header tank and the water level doesn't even fill to the half way mark at present.
Can i get away with ajusting so that it goes about 3/4
Thanks ........
HI
generally 14 litre tank for F & E
and 230 litre tank for cylinder is used.
if you fit a bigger tank it should not affect anything else.
If your overflow and ball valve connection are high enough ,Yes!
Are you sure you have the correct tank and not heating F&E?
Why do I get the impression you have connected to the heating header tank. :LOL: :LOL: :LOL:
Very funny but i ain't that much of a dumb ass - :D I always do my research even though sometimes i do still make mistakes.
-No I haven't changed any pipe work YET - That's still debatable, if my PRV Honeywell monster doesn't do the trick.
Terry it's defo the main water tank and not expansion - reason i know this is, the little baby basin sized bowl is right next to it, :) but thanks for your concern and i will adjust the ball valve to accomodate more H20 - cheers
Geek link http://www.lsbu.ac.uk/water/
LUNAT - cheers muka for help
It dosnt matter on the capicity its on the head (height of the tank).
But you do need a tank that can supply your need.
I always do my research first
In that case you would call it an storage tank. And whats a baby basin size bowl thats next to what
Sorry that i didn't use the correct term for the storage tank, hence the reason that i'm on here to start with. That's the whole purpose of having a network forum so that people can exchange information and not have to read sarcastic comments !!!
What's up had a bad day
No, Thats why were here so guys like you don't connect the shower up to the heating system :rolleyes:
Your here because your bored and want to hassle someone - so it appears anyhow - read back through the thread and it clearly states no pipework has been changed. What's your problem !
Thread was going well till your useless, nonsence, waste of digital input came onto my Visual display - It's no good trying to pick a fight over the net. No such thing as cyberkill !!! :evil:
Status
