Hi. I have a loft which has joists with gaps between about 300mm a few a little more maybe 310. I need to insulate cheaply as possible to 100mm.
All the standard roll insulation i can find is 1140 wide. Apart from discarding the last 240, or fiddling about to cut and fit two strips together to make 300, is there another way?
A forum search turned up a topic from about 6 years ago which said 600mm roll was available and i actually have one roll left over from years ago 1200mm wide but i cant find a current supplier.
Must be loads of houses with joists on 14'' centres - i must be missing something!
Very grateful for any help recieved.
