Loft insulation advice - unusual construction
11 Sep 2021
Hi
I'm keen to insulate a loft with unusual construction (see below). I'm hoping that can be the usual "roll out some mineral wool" to a depth of 300mm (and raise any boarding above that by at least 50mm). But am weary of condensation risks (all the more so as this is a timber frame, timber clad house).
ROOF:
There's about 180m2 cold pitched roofs, seemingly built over an older, pre-existing flat roof.
  • Construction appears to be uninsulated joists, topped with a flat roof made of a slab perhaps 75mm thick of compressed straw (!), covered with what looks like bitumen (or similar).
  • I think this may have been the original flat roof, probably constructed somewhere between c. 1955-1967.
  • On top of parts of this flat straw/bitumen roof, there's c. 50-100mm of glass mineral wool insulation (see photos); other parts there's nothing or boarded storage (there are also parts where some of the straw's been removed).
  • On top of this old flat roof, a lightweight timber frame was built, covered with a membrane and then sheets of Decra Classic (or similar) lightweight metal/composite roofing “tiles” (with what are I think GRP gulleys). Rafters are generally (a whopping) 1200mm.
  • The whole structure appears to have very poor thermal performance, and so need better insulation. However, given the unusual construction, it’s not obvious to me how best to economically deal with it (and to do so in a way that doesn’t create the risk of condensation issues).
Parts of the Decra are in poor condition - cracked / banana’ing / patch repaired. However, we’re not aware of any obvious damp / water ingress over the past 18 months or so (may have been a problem before that). Probably warrants at least some patch repairs.
jHSsSkdLP5xwL2uyGuLMZ63fAcTvXiXIEM2_bhsiq-S6NOHZ0T2H8_W1JxTtd6jlrBvMOwJwLbG-xfopMzvP8ek-SL8oZlJxeJogYQmA_zkMG3NTcRfSOuBLKT8D-RZTCC1C7S47T-IgcWyl-U4iiw
Note bending of Decra around chimney (suspect due to weight of leaves which we found there - now cleared)
mobkfDwllcT9NPOLIFTXmuxoSRG5csllOhBYD_nHlwoYQdmU6hBqswYA8Ljc87n8GQ5zqP_pvREhjmPeNYPgeQQbcOslGfUVKpqcdOG_s9nPC0vP6Lqqpp1Rn0jIe6JeCyD-y_DNWSD8NX3InSzTdg
Loft hatch area showing straw - between ceiling and cold roof
YDWgdwh10hOeaGr4eA9fsQ-c6F5GoEwqDYXyANupjX7Ayoo6PyCGez9PyDK_3aFlwt00GBfn42mFXlQh47m0Ih973Rss2f8g-bPP0HS9LTS4_fbOaEZ5FPTa9aVOi-4EZ3s9vGeHUFWl_JPtUdJ4cw
Inside of roof - section of strawboard lifted to show joists (uninsulated between joists)
UYqEHaiaupXgunOV7imDT0g_AAGVLE_MJnkvvOdcgQ46Qjlr4O6HwsQYt57MkdiJzcCNtCGATP3QqRr8ODyYxD1wYeaNjppBcKBaOYQZ_9dkKp11_JjvWrpr6f9sPg3KAvNz0HeuS_8FhwVBBUIlSA
xmW4YfoLo9yBnekVnHzEgMmuMxmA9g4WbKrWom9IUoB7DADvO0zwIaiKzsfwUTs5e7p0mWBQ1XgbnbBAZ0hJJV35o2nb4ZCU8h0uJ-H8Tk8IsqTMsN-ckXE2Rw76Jcb5hlat-D4UslGtaTbn7MOyMQ
Showing 1200mm (uninsulated) rafters etc. The thin Decra is then on top of this.
QAeSXFsWpy5XfJAHtGlG3kfIi9RsPf5GQ3HVQyoyPr5FKEIv_azNYqhK1iUw39g78GbP-ev4Y5Jk98frp3Gj04RXFw84B_8kwL-WLKCOu1izDnk8bf_0BfZ-PzyPz461pNjfn2N0VhpNxWz3zGd-6g
Some parts have up to 100mm mineral wool insulation above the old straw flat roof
Would mineral wool (up to 300mm) - or possibly sheep wool ( (more expensive but no nasty loose fibres in the cold loft space, which is used for storage; good resistance to any moisture) laid out over the old flat roof (i.e. on top of the bitumen felt) work? I'm hoping/guessing a VCL isn't necessary (or the ceiling and//or bitumen already acts as one).
The (considerably more expensive) alternatives would seem to be:
- Open cell spray foam of the entire inside of the loft. But concerns about impact on insurability/mortgagability, etc - seems some insurers/banks won't touch homes insulated with the stuff.
- PIR warm roof - but probably only sensible if re-roofing (which I doubt we can afford). But the structure may not support the weight of PIR plus new roofing materials. Ultimately, however, finding a solution to the roof may be necessary (perhaps just patch repairs/replacing the Decra).
I can reinstall those cut out chunks of strawboard (which a previous owner or their workmen cut out and lifted) tape it down, and roll out layers of mineral wool over most of the strawboard area (hopefully there's no sense in a VCL). There are a few potential exceptions / complications:
- Some of the loft (maybe 50m2) is boarded - raised on wooden battens about 10cm off the straw board. This would need lifting, raising (perhaps on large loft lefts) and relaying. Other parts are not boarded, with things stored directly on the strawboard, etc (maybe 40m2). So a similar approach would be needed there.
- There are some areas where the straw has been cut out and there's wiring/piping in it. Fortunately most or all of that area is over the utility room and/or pantry, and I'm less fussed about the insulation properties there. If it's not ok just to put 300mm mineral wool directly over this, it may be possible to fit some 150mm PIR board over it to seal it off - but I suspect for much of it that won't work (not level), so mineral wool would be preferable if that won't create any issues.
Fluff should be fine , be it sheep's wool or what ever.
The old flat roof will be ok as a vcl.
You still might consider ventilation of the voids .
Lots of foot traffic on the decra
Thanks.
I'm hoping we can take off some of the Decra and bend it back into shape; re-roofing is, I suspect, outside of the budget!
I suspect I'll take the plunge on "fluff", be it mineral wool, or sheep wool, or something else. I spoke to an architect who recommended Wood Fibre Boards (and wood insulation generally) for this type of property, though it does seem to be significantly more expensive ...
The loft itself is a cold roof - pretty well ventilated already though soffit vents (though could always add more if needed), if that's want you meant by ventilation of the voids (?).
