I have been doing some diy work in my loft which has an up and over roof.
I have stapled insulation foil over the rafters and then put plasterboard directly on top of the insulation foil - which I now think was a major mistake.
Before I had a feeling that I made a mistake, I had the loft plastered and it has just finished drying. Yesterday, I noticed a bit of a damp patch appear near the bottom of the pitch (in the eaves) and it got progressively worse throughout the day.
In the evening, we noticed the damp patch started drying up.
I wanted to ask people's oppinion about the work I have done and what the possible cause of the damp patch could be.
- Did I make a mistake by laying the plasterboard straight over the insulation?
- Should of I battened over the insulation and then put the plaster board on the batten so to create a bit of an air gap
- Do you think the damp patch is condensation due to the insulation not being able to breath? Or could this be a bit of left over moisture from the recently dried plaster (it looks completely dried to the eye, but may not be behind)
- If the problem is that the plasterboard is on top of the insulation, is there a quick rememdey for this? Or will it be a case of removing it all and starting again?
Thanks in advance[/list]
