loft insulation: joist depth and boarding over
16 Mar 2005
1970s bungalow. The joists in the loft are something like 4 inches high.
Currently there is some old scratch "glass-wool" insulation to a depthy of 2 inches. The central part of the loft is then boarded over.
Modern builds use an insulation depth of 250 mm.
How can I implement something like this depth for my loft?
* I will have to do without loft floor boards; or
* I will have to squash the insulation -- surely this reduces the effectiveness.
Whats the secret to upgrading a 1970s build to modern insulation requirements?
Mike
Mike
Hi There,
I'm in a similar situation.
Our house is a 1910 ish mid terrace, the ceiling joists are only about 60mm deep.
We want to get rid of the existing insulation and replace with new 170mm insulation, i would also like to at least part board the loft.
As you say, squashing the insulation will reduce efficiency.
I was considering laying the insulation then cross battening the loft but am unsure about what size timber I should use to do this.
I'm thinking that if i cross batten, at least the insulation wont be totally squashed, instead only every 400mm.
