Loft insulation with rigid material
30 Dec 2005
The ceiling of the top floor of our house is made with wooden beams about 50cm apart and tongue and grooved timber nailed on top. This gives a flat floor in the loft, (the rafters are underneath) but there is no insulation at all.
I want to lay rigid insulation material directly on top of the loft floor; 2 layers, done in a way so that the joints between each sheet of the bottom layer is covered by the top layer. I will seal with some sort of foam, around the edge of floor/ceiling as at the moment you can see daylight from downstairs.
Should I cover this insulation with any sort of plywood material ? Has anybody used a similar method or been in a similar situation?
