Ive recently moved into a house where the former owners took advantage of the government schemes to insulate their home, they have had a decent depth of rockwool type insulation put in the loft, between the rafters is filled and then a second layer is laid on top of that at 90 degrees to it.
I would like to turn the loft into a usable space. Im keen to keep the heat insulating benefits but the space isnt very tall and the only way to be able to board out the floor area seems to be to lay additional rafters on top of the existing set at 90 degrees. Id rather not do this as head height is already a bit poor.
I was thinking it might be a good idea to remove one layer or insulation and board it out, then use something like kingspan to insulate in between the roof timbers instead, does this sound sensible? Alternatively could I use the rockwood that ive removed up against the roof or would it cause damp problems?
