Loft insulation
28 Mar 2016
I am planning to insulate my loft ceiling (floor, not rafters). This is just for storage and not habitation.
I want to use Celotex insulating board, rather than Rockwool.
If I insulate between the joists and then a layer on top of them (to achieve the required U-value), can I then place chipboard directly on top of the Celotex, or does it need supporting?
Do I also need to leave a ventilation space between the plasterboard and celotex in the joists to avoid interstitial condensation (as with insulating rafters?).
Thanks. Will celotex hold weight if laid directly across the joists, or do I need to support it with chipboard underneath (and then more chipboard on top)?
Should be fine, just make sure it really is supposed by the joists and not resting on the ceiling itself
