Hello,
The recent cold weather has made me want to top up the loft insulation. The existing insulation is 100mm laid between the joists and I’m looking to lay another 170mm across the joists.
I want to keep as much heat in as possible but I’m concerned about the possibility of condensation.
The soffits are not vented. Can I push the new insulation into the soffits or do I need to leave a gap? If so, how much?
Thank you
Thank you
