loft insulators
29 Jun 2008
West Midlands
Do loft insulators have a responsibilty under the building regs or bs7671 to ensure that cables are not just surrounded in insulation. Dont get me wrong! I carefully clip, but i see some really poor installations where cables are lifted, pulled and surrounded by the insulation. Lighting circuits are usually ok with the installation method but shower cables are more easily compromised. it appears regardless
Yup - Building Regulations are quite clear that:
1) Adding loft insulation counts as building work.
2) Building work mustn't make other controlled services or fittings less compliant than they were before.
So if loft insulation makes a circuit unsafe then that's a contravention of the Building Regulations.
and the idiots who lay concrete of copper plumbing and wall insulation blown over pvc. Even though the cable should be protected through a cavity
