Loft ladder and stilt loft floor
17 May 2015
Hi. About to start flooring my loft with stilts as insulation is high. I'm not sure what to do with the loft ladder and how to fit it. From what I have seen loft ladders are attached to the hatch frame and also the loft floor. If I have stilts throughout the ladder won't fit to the elevated floor. I was thinking of removing 1 of 2 layers of insulation where the ladder would sit inside the loft (about 1 metres worth),board onto the joists and attch the loft ladder to that. Then when you climb up the ladder you would step onto the lower section then step up to the stilted section. Would that work? Cheers
Yes,you have to create a secure landing area for the ladder and yourself so screw chipboard down from hatch opening as you have mentioned.
Loft Stilts, call me old fashioned but I don't like them,i hate them,i would never use them,when ever I had to go into a loft with these I always think to myself I hope these are safe. well that's my opinion :mad:
i dont like stilts they increase point loading and dont spread the weight
if you have a stilt at 400mm centres with the joists at 400 centres will give you a 580mm unsupported span as its the diagonal unlike cross braced 100x50mm timbers that will give you a 400mm span if they are spaced 400mm apart
