Hiya,
I'm after a proper loft ladder. My problem is that the obvious push and slide system isn't possible as my loft opening is right at the back of the house so no where to slide it. Unless I knock a few bricks out into neighbours loft and slide into there
I can't access it from different angles as either side of the opening are the chimney stacks which would block the push and slide system!
So need some sort of ingenious system that is wall mounted and folds into itself when not in use.
