hi,
i have a series if lights in my loft ( 8 or 9 small flourescent lamps ) and am hoping to connect the installation permanently through a switched supply box in the loft, which i am hoping to connect to the ring main socket system.
in the upper bedrooms, clearly labelling the wire so to avoid confusion later
so that i can have lighting in the loft whilst re wiring the electrical cables to the upper bedroom ceilings.
using standard lighting cable through all the lighting.
is this satisfactory?
