Loft lighting
5 Feb 2004
I have hung two fluorescent fittings in the loft space by running 1.5 lighting cable from one to the second one what must I do now to power the lights up will I need a junction box
You have suspended two flu lights using cable?
I don't quite follow.....
i understand (i think)
the easiest way is to find the last light on the floor (that being the ceiling of the floor below, if you see what i mean) below and tap into this.
you will know which it is as it only has 2 cables (others will have 3)
let me know when you have found it, and also get some more cable and a light switch patress clips etc
I have found the last light on the floor (that being the ceiling of the floor what is the next step
similar to
where on the drawing it says "to next light" that is where you connect the cable to your loft lights.
at a conveiniant point you put in a switch (cable goes in and out, from exisiting to new lights)
in the switch you connect the red to C (in) and L1, (out) also the earth to the earth termianl of the patress
then up to the first light
this light you connect it as normal
you then run a cable from the first light to the second and connect as normal
(i believe you have done this bit already)
at all places the earth should be covered with green/yellow sleaving
switch mains back on, and go into your loft press switch and admire your handywork, send me 80p, and do not step backwards as the loft hatch will still be open
