Looking for opinions on how to best solve my loft quandry!
Main requirement: lay boarding to 3m x 1.5m section of centre of loft to improve storage.
Subsidiary Requirement: increase insulation - currently only 70mm of glass fibre (probably original - 1981 built house) between joists.
Contributory factor: Low head height, circa 1.9m in centre (i'm 1.8m tall), which rules out raising the loft floor too high.
Options:
Options:
- Board directly over existing insulation.
- As 1, but cross-brace (i have some 63mm x 38mm timber already) to create air gap.
- Replace 70mm wool with 70mm insulation board between joists to double the R value, and board over.
- As 3, but also using cross-bracing to create air gap.
- As 4, but also have board insulation between cross braces to bump level of insulation up. e.g. 70mm between joists + 50mm on top = circa 240mm equivalence. Plus the loft boards and it's near enough the recommended level.
