Recently a pipe to my boiler which is located in the loft area froze due to the tenant turning the heating off while he went away for a few days. Could have been a lot worse as all that happened was a pipe joint pushed apart and separated and so was pretty easy to fix.
Whilst in the loft it was noticed that it was a bit damp up there - the roof was re-felted several years ago and four vents in put in the tiles to supposedly stop any condensation but is seems in the coldest weather it is not quite enough.
With the boiler issue in mind I am thinking of adding insulation between the roof beams themselves to make the space in the loft more insulated and help reduce the likelihood of condensation and also help protect the boiler - I see adverts for spray foam and also for fibre boards - the cheap aluminium sheet looks a bit of a con so I presume best avoided. What would others recommend?
