got calcs back from se, he has spec'd 2 203*203*71 beams spanning 7400mm carrying floor, purlins and roof for a loft conversion, thats a big beam at over 0.5t, there is a 152*152 spreader running in the middle between them to keep them from twisting im guessing. does anyone know is there is another size beam we can use or doubled up pfc channels, or a larger ub beam, that might weigh slighlty less and be easier to install, i know we could put 2 splices into it, bringing the weight down to about 180kg per section ?
i can give you the loadings if you need, it is about,
one carrying dormer, dead load is 24.35kn, live load 45.35kn
other side is dead is 18.16, live load 38.25kn
any advice would be appreciated
hamazz
hamazz
