Log burning stove
2 Mar 2003
Yorkshire
This might sound like a daft question,
but can I have a log burner (cast iron type) in my front room, even though I have no chimney?
I currently have an electric fire which is against the wall (this is an outer wall) and was wondering if I could drill through and fit some sort of flue running up this wall (externally).
I really want a proper flame fire either Log or Gas as the electric fire is just plain rubbish tbh.
Many thanks in advance
Beatts
Errr, most definately no if you want to burn logs but you can get gas flame effect fires which may suit; they dont put out any heat though.
You may be able to create a chimney... go to Google and type twin wall flue.
Hi Beatts
Yes there is a possibility of installing either a solid fuel stove or gas stove by running a twinwall insulated flue up the outside of your property, normally this will need to extend beyond the full height of the property.
There are too many regulations to list here so a suggestion would be for solid fuel to logon to the HETAS.co.uk website and find an installer in your area who could visit your property and advise accordingly - particularly regarding venting requirements / smokeless zones / hearth issues etc. And for a gas stove which is an efficient unit, you can log on to Gas Safe and similarly find an installer who will advise you how they can legally fix it for you. Either option requires you to use a qualified engineer
Yes anything is possible, I have a multifuel stove in my conservatory with no chimney but will say the twinwall flue is not cheap and can be dearer than the stove itself. It's the best investment I have ever made, I'm in the conservatory every night even with the snow now! As mentioned get the HETAS installer round for advice, don't be put off by the building regs, it's normally straight forward.
Beatts
http://www.stovesonline.co.uk/wood_burning_stoves/Flue-and-Chimney.html
Lots of info - you can indeed have a burner without a conventional chimney
