Hi im new on here so hope im in the right section
I have read a few threads but not quite sure they answer my questions 100% so here goes.
I am looking to but a log cabin 3m by 3m the cabin has 28mm log walls on the outside and then a 70mm gap and a second floating 28mm wall no studs. The company can supply wall insulation whih is foil backed Polyurethane 70mm thick to fit in the cavity ( no vapout control layer or breather membrane ). the cabin will be used all year round and probably have a small electric heater in winter but wont be a gym or anything like that so minimal moving around etc.
I was looking to use a better sound insulator as im not sure if Polyurethane is that good as a sound insulator . I was considering buying 70mm rockwool flexi slab to fill the cavity. So the questions i have are:
Do i need to put a Vapour control layer on the inside of the insulation and a breather membrane on the out or can i get away without it?
If i do need it will i have to have an air gap between the membrane and outside wall as this will be a pain to achive?
If i do need an air gap i was thinking of using 10mm battons and staple the membrane to that will this be enough of an air gap?
Im also not sure how to go about fixing a vapur control layer up can i just stick it to the insulation ?
The membrane and Vapour control layers i have seen seem to be in 1m widths which will obviously need lapping and taping.
Any help or advice would be approciated thanks
