Hi, my dad has recently had a Logic Ideal 30 installed and it never seems to stay off. When he sets the room temperature to a desired level it will reach it but never actually go quiet all the time, very rare it will go off completely it just cycles in the background. The instructions say it should only cycle 6 times an hour.
It has a Honeywell CM921 thermostat that will only go to 26oC even though it can be programmed to 32oC. The thermostat was installed in the hallway but we had to move it to the living room because the hallway made the boiler constantly on trying to heat the cold hallway.
Should the boiler stop cycling and stay off for a while, is the thermostat in the right place and should we be able to programme the thermostat past 26oC if we want. Thank you in advance
