Hi all,
as a complete newb to the self build world I'm about to embark on a single storey flat roof extension to open up the ground floor, usual stuff - lots of glass etc.
To get the open plan into the new extension I need 2 RSJs to hold up the 2 skins of the back wall. I want the steel to be recessed into the ceiling to give a continuous ceiling. All the guidance says this is done after the extension is built and weather tight.
What I'm wondering is, how do you build the extension and make it weather tight when the inner end of the joists are to be fixed to a timber filler in the steel and the steel isn't in yet?
I have suggested fitting the external steel first, then building the structure into it then, when done, do the internal steel and knock through.
Am I being an idiot???
