Long Cure time for Flex. Adhesive
19 Jun 2006
Norfolk
Hello All,
I have been using Homebase flexible Floor Tile adhesive which said to use 3-5mm depth per tile.
I didn't realise as I was tiling, but after keeping my level, the floor level dropped so I ended up with over 7mm depth.
This is taking an age to go off. (48 hrs so far)
Would it help the cure time to blow air over the area? (No grout yet)
any opinions would be lovely.
regards, Alex
I'm assuming this product is of the pre-mixed variety? This is just one of the drawbacks of using pre-mixed adhesive. The others are poorer performance and expense.
You might speed things up a bit with a dehumidifier.
yes, its pre mixed.
I do have a de-humidifier (I didn't think of that)
many thanks,
Alex.
that add you uesed is bad for drying itme 7mm no prob warm air will help not to hot
