Hi All,
I have built stud walls in the past and all have been under 3 metres which means that the top and bottom plate are a single unit. I now need to build a couple of stud walls which are around 6 metres in length. Can someone please advise on how I can strengthen this and specifically the relationship between the top/bottom plates and the vertical studs, given that I will need need to two piece for the top and bottom frames.
Thnaks in advance.
Thnaks in advance.
