An En suite shower Room (no WC) that I inherited had the waste pipe for the shower and Basin notched into the joists, going totally against Regs and weakening them beyond belief.
I propose to take this pipe out and strengthen these joists with steel and look for a new route for my waste pipe.
My suggested route will take the 2" waste pipe 3 metres running parallel between two timber joists, it will then be dropped below the ceiling and run a further 4m metres before it reaches the soil stack. At the head of the waste run I plan to install an AAAV.
I have checked Document Part H and it does go against Regs as far as I can tell, off the top of my head they suggest just a 4m run is allowed.
I'm still keen to do the work regardless of the Regs, does anyone see any problems with my suggestions??
The 2" waste pipe will be used by a Basin and a Wet room Trap.
