I'm fixing a semi-ped basin on 12.5mm plasterboard which is screwed and glued to the old plastered brick external wall.
I have some Fischer WST140 (140mm bolts) already, which I don't think are going to be quite long enough.
If you add everything up it only leaves about 40mm penetration into the wall plug. I would have thought at least 65mm would be necessary.
I don't have experience of fixing a semi-ped before. Naturally I want the fixing to be as good as possible as the basin is damn heavy, Ideal Standard Purity 550mm by the way.
Anybody know of any longer fixings than the Fischer 140?. I believe these are their longest anyway.
Cheers in advance.
Cheers in advance.
