Remortgaing on a buy to let, surveyor put a £10k retention and recomended a structural survey as evidence of movement. When I phoned him he was pretty certain all ok and was passing the buck and watching his back (his words), I said if I pay for SE report and it was satisfactory would he pass survey and he said yes. Had report done, all ok but recomended 1 the drain and gully adjacent to front wall repair/replace if and as necessary within next 12 months to prevent longterm softening of the foundation supporting stratum that is probably responsible for the limited longterm differential foundation settlement that is occuring to the property in this area.
2 It would be necessary to stitch together the inner and outer skins of gable wall and outrigger side wall if any lateral distortion of these walls is progressive in the future but such remedial works are not necessary to date.
The surveyor has now seen this report but is refusing to confirm to lender that no further movement may take place on property, even tho SE report confirmed this. So the lender has declined the offer. My broker is going to ring ther surveyor to see why he is not accepting the SE report and not confirming no further movement. The SE has told me if I got the drain tested/repaired if necessary he would then re survey it and pass it off! I have spend £600 here and don;t want to loose it when there is nothing wrong with the property. I have had 4 previous surveys done and all said evidence of movement but not progressive. Any advice would be welcome, it doesnt seem fair that he reco's a SE report and then refuses to commit.
